phone not working
sammy68
My phone won allow me to manually connect to 48 network I also tried making apn but that didnt work
Is the problem specifically with data access - i.e. can you make/receive calls and send/receive texts OK or not?
If the problem is with data access then review this thread including the generic settings, settings for your phone or one that is similar and my first post in the thread about the Tweakker APN app which may help.
If you still can't get data/internet access working then log a support query to get 48 to advise:
