number still not transferred
I registered with 48 and asked to move my number over last night but it was after the operating times so I thought it would be sortted this morning but it still says transfer in progress and it has been well over 2 hours. When i go onto the page to pay a membership it is giving the number i want so do i have to pay a membership first to make it work? I dont want to top up to the wrong number if my number still hasnt been moved yet.
As explained in the key post you should contact 48 support if it's taking longer than expected to port your number:
How do I keep my old number?
