OK - so for some reason it looks like the porting of your old number from Vodafone is held up...
Are you sure that you entered the correct details - e.g. I recall having to choose between bill pay, prepay registered and prepay unregistered and if you choose the wrong one the process may get delayed.
You weren't on billpay and still owe Vodafone money in which case they may block the port until you're paid up.
Best to log a support request to ask 48 what the story is.
If it's taking too long then contact support as per this key post:
Can you receive calls on the 089 number in the meantime? And make them if you bought membership already?
