my sim card
hred
i have a windows nokia lumia 520 and i have unlocked my phone but it still says no sim/ invalid sim when i try make calls etc how do i fix it so my phone works again ?
7 REPLIES 7
Are you sure the simcard is fully registered to the network!?
Check here : http://www.48months.ie/dashboard
And are you 100% sure that the phone is unlocked? Can you try another SIM in it?
sineadpoli
Hi flashforward 3 years and I am in this position, what did you do to resolve? Got an unlock code from unlock.ie and nothing they recommend to do even match my settings HELP NEEDED
Well you need to unlock your phone anyway.
Did you do this?
Yes I did get my phone unlocked
So is it working now?
