mobile data not working
When the call and text came back from being down the other day, data did not.
OK - I guess that the only thing for both of you to do is to contact 48 support directly for advice/assistance:
Try manually searching for and connecting to 48 (or O2 if 48 is not listed) and see if that helps.
puprua
still cant make calls txts r use internet , this is really not on i need my phone for work going through the formalaties online is ridiculous at this stage
I already tried manually connecting to 48 and it didn't work. I have calls and text just not internet
