membership
why does some users not have the option for a standard membership?
Yes - Standard €10 all calls/texts membership is only an option for those who were members before 5th March 2013:
http://community.48months.ie/t5/Need-Help/I-am-unable-to-pay-the-normal-standard-membership-of-10/m-...
http://www.48months.ie/boiler-plate/legacy-plans
It depends if you joinged the network before or after the membership plans changed around i think!
When did you join 48?
