lost phone
Hi i lost my phone and i need to report it to the network and get the handset blacklisted...how do i do it??
First thing to do is order a replacement 48 SIM which will disable the SIM in the phone and prevent anybody else using your 48 membership/account/credit/allowances:
I don't know if 48 can/do disable stolen phones based on their IMEI as outlined here:
http://www.garda.ie/Documents/User/mobile%20phone%20english.pdf
but you may want to log a support query to ask (assuming you have the phone IMEI):
