keeping number
mmaazzaaass
Hi i wanted to keep my number i made all steps i have to do but nothing changed. I also tried to do with other 48 simcard it still did not worked. Can someone help me ?
You mean you can't log a support request by following the instructions here?
What happens?
What exactly do you try?
What error messages do you get?
In the meantime if that doesn't work then you can try this link:
http://help.48months.ie/anonymous_requests/new
or email support here:
support@48months.zendesk.com
mmaazzaaass
And i can't log a support request.
What happens?
What happens?
yes i tried that first link and i fill up everything and in the and I pushed submit but nothing heppens . I'll try to send to that email. thank you very much.
OK - good luck and let us know how you get on.
