iphone5 setting ?
Thanks sorted
Do the iPhone 4/S settings not work?
EDIT: sorry - just noticed here that you did try them and they didn't work for you...
http://community.48months.ie/t5/Need-Help/Settings-for-Apple-iPhone-4/m-p/1206#M390
If not then maybe log a support request to get 48 to advise.
They might also need to update the internet settings key post to add iPhone5 if it's different from the others...
iphone5s setting
can you tell me how you got your iphone 5s settings sorted?
Did you try the links that I posted above!?
Thanks sorted
Just curious - how did you get it sorted?
