Moving Old Number to 48
I signed up for 48 a few months ago and got a new number (which I've been using since.) I have an old number on another network that I would like to move to 48. In this case, will I have to get a new sim for the moved number or will it be ported to my existing 48 sim that I've been using? Also, what happens to my membership when this move occurs?
Thanks in advance.
You can port the number over to the SIM that you are using and retain your current account/membership/allowances etc. See here:
How do I keep my old number?
