iphone/microsim inquiry
Hi I just got an iphone 4 and ordered a a micro sim from 48. I'm already a memeber of 48 so will my number be the same on my new sim and will I still have all my numbers?
sauce
Hello Sarah,
Yes your number will still be the same but sadly all your numbers will not be saved.
If you have a little search on Google you might find others with the same issue and they may point
you towards a program that backs up all your contacts for you.
But of course you can also spend hours writting them on a piece of paper 😉 But i dont think that would be the best option!
If this response was helpful make sure and accepted my answer as the solution. And of course +1 kudos.
~ Alan 48 Community helper
sauce
Hello Sarah,
Depending on what phone you are moving from and to it may be possible to transfer contacts from the former to the latter. If you post more details of your old and new phones and where contacts are stored (SIM or phone memory) then somebody may be able to comment in more detail.
