internet
hi im having problems with my internet i followed the settings for the samsung galaxy s2 i was wondering if you can help?
If you manually configured the relevant settings correctly did you also enable data roaming?
Presumably you have a membership or add-on with data access included?
Have you tried Tweakker APN?
