internet
kittykat
My phone internet is not working eventhough i have credit, please help,
Thanks
Try all of the steps here
Make sure that you have an active membership, and a data allowance bundled with your membership or internet add-on.
Hope this helps
Hope this helps
Hi I got Xperia z2 everything is working except my Internet n I just topped up it says I have 1gb but doesn't work can u fix it quick thanks
You need to configure your internet settings for internet access to work.
Try the online configurator - whichever link is relevant to your phone:
Make sure to enable data roaming.
