iPhone se
How do I set up my iPhone SE for Internet, it's iOS 9.3
7 REPLIES 7
Use the settings/instructions here:
iPhone SE doesn't have an APN button
What do you mean?
Do you mean that you can't do this?
https://support.apple.com/en-us/HT201699
If so then that's yet another iPhone problem (Apple seem to make it as difficult as possible to use iPhones in my experience!).
Maybe this will help?
http://forums.macrumors.com/threads/unlocked-phone-but-no-cellular-data-network-settings-bug.1360298...
If not then please post a screenshot of your settings page where you would expect to see the option to configure the APN/internet settings.
How do I send a screenshot? There's no button to add a picture. The iPhone SE simply does not have an APN button. And the settings I was sent when I put in the sim couldn't be downloaded
How to take a screenshot on an iPhone/iPad/iPod:
https://support.apple.com/en-ie/HT200289
Did you try the links that I posted above?
Sounds like it's yet another stupid iPhone thing that you cannot configure your internet/APN settings directly.
You may need to get onto Apple about that as it's not a carrier/48 issue.
By the way when you (re)insert a 48 SIM you always get the "uh oh - we couldn't send settings ..." message and it never works anyway - at least it has never worked for me on about ten different phones so I don't think that it works at all. So that problem is not specific to your situation here.
Any update?
