hi, i received my replacement sim today, says it cant be activated and to contact an agent, thanks
Are you sure that you're trying to activate it as a replacement SIM and not a new SIM (which would end up on a new account, number etc.)?
Can you post the exact error message - a screenshot would be ideal if possible?
If you need to contact 48 support about this then you can do so here:
Hi, solved in live chat thanks
Great - glad you got sorted so quickly.
What was the issue just in case it helps somebody else avoid the same problem?
actually no idea, it was a replacement sim. I was logged into my account but it said that it couldnt be activated to contact an agent. The agent was able to register it online instantly.
