going abroad
devil_vs_god
will my phone will work when i go in a diferit country for hollidays?
Just to clarify - you don't HAVE to buy roaming add-ons for things to work but it is generally cheaper to do so.
Roaming add-ons are EU specific and not relevant if roaming outside the EU.
Outside the EU all services are charged from your credit balance and your membership or add-on bundled allowances (e.g. for calls, texts etc.) are not used.
The price list clarifies matters.
http://www.48months.ie/boiler-plate/other-call-charges
Hi devil_vs_god
When you go abroad with your phone, you need to buy a roaming add-on to ensure you can still call and text!
Simply click here and choose your add-on
https://www.48months.ie/buy/roaming-packs
Yours,
Camille
Community Helper
