data
sandra03
Hi, I installed the message in my mobile phone for data but data don't work. What can I do? I have a huawei u8650. Thanks
What do you mean "I installed the message"? What message?
Did you configure your settings?
Try the online configurator:
http://48months.tweakker.com/choose/Huawei/U8650%20Sonic
If that doesn't work then download the Tweakker APN app over wifi and use it to configure your settings:
If that doesn't work then you need to configure your settings manually:
Internet Settings
Remember to enable data roaming.
And you obviously need a valid membership and a data allowance as part of your membership or add-on.
Internet Settings
