- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report this post
16-05-2014 10:42 AM
Just topped up by €10 and it told me to text monthly to 1745, did that and it said oops you can't buy this membership or add on. What do I do
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Report this post
16-05-2014 11:12 AM - edited 16-05-2014 11:26 AM
If you were a member before 5th March 2013 then you are able to buy Standard membership by texting the code "standard" or "monthly" to 1745. If you joined after 5th March 2013 then the only €10 membership available to you is Guido which you can buy by texting "guido" to 1745.
If you were a member before 5th March 2013 and "monthly" or "standard" does not work then there is some problem and you should contact 48 support if you want to by Standard membership.
Otherwise I presume that Guido membership will do you?
Sounds like the website is a little misleading/out of date in telling you to text "Monthly" to 1745 since that is not available to everybody. I've flagged the issue with 48 support.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Report this post
16-05-2014 10:45 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Report this post
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Report this post
16-05-2014 11:27 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Report this post
16-05-2014 11:29 AM
Great - glad it helped.
Hopefully 48 can update the website to fix any misleading instructions...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Report this post
17-10-2014 10:36 AM
I topped up by €20 and text monthly as it told me to but my internet didn't work so I text it again and can back you are all sorted etc. but I still have no internet. I normally pay my card but I only had cash so I've topped up this time. I only error use the don membership and now it's saying I'm on the standard one ??? I don't want the standard I want the don and also when I checked my usage on my 48 it's saying I only have 26mims landline calls left but I haven't made any landline calls ? Can someone help please as I just wanted to top up to re activate my membership ?
Thanks
Tara
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Report this post
17-10-2014 10:45 AM
I can't remember but is "Monthly" the code for Standard membership?
What does your online account say about your membership status and expiry date?
If you bought a new membership before your current one is up then the new one stacks and does not kick in immediately.
Did your internet work before? If not then you need to configure your internet settings for it to work.
If it did then check that your settings are still correct.
If necessary contact 48 support about some or all of these issues:
