connection
annakuom1
I just got a micro sim and when I put it in my phone it just says emergency calls only. I tried searching for networks but it wont let me connect to 48...
Is this your first SIM with 48 or a replacement SIM?
Whichever it is did you use the correct registration procedure?
Need to swap your SIM?
What does your online account say?
You probably need to contact 48 support about this:
6 REPLIES 6
Did you register the SIM?
Unlock guide
Well I ordered one and it said it would have my number and my credit on it and yes my phone is unlocked...
@annakuom1 wrote:
If you can address some of the questions that I asked then I might be able to help further.
But if 48 support are already sorting you out then that's fine.
Yeah they already sorted me out thanks:)
