can't send texts
gerber
Today I lost the network for and hour or so till I rebooted. Since then can't send txts. Can receive them and use internet. Have txts left on plan. Network is on and signal good with usual 'r' over signal bars....any ideas?
Any update?
Assuming they're not international texts or MMS that need cash credit then I think you'll probably need to contact 48 support for advice here:
Any update?
gerber
He thanks so much for getting back . I went online and got solution.had to change message centre num. All good now. Must have got messed up when knocked off network yesterday. Thanks again!
Seems odd that it lost the SMSC number but glad to hear that you got it sorted.
