barred
its saying i am barred im not recieving any texts or calls and i havent payed memberhip in a few months . if i top up will this be removed ? need help quick ! thanks
Barred or deactivated?
How many months since you topped up?
If it's less than 11 (I think) even you can get your account reactivated by contacting 48 support.
if you are barred and need the bar lifted then you also need to contact support.
In either case I think you need to contact support and just topping up or buying membership alone will probably not rectify the situation.
