Will my Internet work in Spain?
laura_rawley
hi, internet will NOT work in spain unless you are on wifi I.E. not using cellular coverage, because its so expensive for data abroad 48 cannot provide this.
martin
Hi Laura,
i'm guessing as long as you have bought a roaming package it should work...
gunna check this out now and get back to you.
martin
Hi will the internet work using top up??I'm goin to Prague nd need t use my whatsapp while I'm there...thanks
No - see previous answers to the same question. 48 do not support data roaming abroad regardless of what membership, add-ons or credit you have. If you need internet access then the only option is to connect via a wifi network.
http://48months.ie/boiler-plate/other-call-charges
"Data roaming can be expensive, so we don't support it right now. We recommend you go find a local WiFi hotspot!"
