Why my internet doesnt work
Hi I paid for tge deal Don and my internet doesnt work please fix it 48months cuz Its necessary
@sissy101 That is quite strange then. Have you got 3G activated along with data roaming switched on? If you still can't fix it after one more try then you can log a request here.
What android version is you Galaxy mini?
7 REPLIES 7
kevinoism
Regular
Well before you blame them and tell them to fix it you need to do a few things. Firstly you have to see if your setting on the phone are correct.
These are the generic settings( Along with some models that have their own specific instructions) that you need to put in depending on what your device is. If you can't manage to do it yourself with this link then say what model your phone is, then more information can be given that is more specific for you.)
http://community.48months.ie/t5/Need-Help/Internet-Settings/m-p/78/highlight/true#M1
^ Internet settings.
I hope this helps.
i just joined aswell today and bought the don for €20 and tried the steps for my samsung galaxy mini and still no internet, cant understand why, did step by step 3 times before contact 48
My internet after all the setting and i have ssmsung note 2
My intetney still not working
Did you enable data roaming?
Do you have a data membership or add-on?
You might need to log a support query to get 48 to help you.
Hope this helps
Have you looked at this post?
http://community.48months.ie/t5/Need-Help/Windows-8-Phones-internet-and-mms-settings/m-p/4210/highli...
