When I changed the card it I lost half my contacts-help!
You mean when you changed SIM card? If so you probably need to put the old SIM card in and move SIM contacts to the phone and then put the new SIM card in.
Maybe you can post a bit more info about your old and new setup and the problem?
Worked-thanks a mill!
Great - glad it helped! Smiley Happy
