Waiting on number to port over to 48
Hi,
I registered my sim at around 7am this morning and I'm still waiting for my number to port over. I was wondering could you look into this please?
Thanks
Is your old sim still active (call/text)?
Can you check your membership page for notification message's about the port...
It is a two hour process,however somtime's it can take longer.
Lastly, contact 48 support by clicking the link below & follow step's given.
http://help.48months.ie/tickets/new
Yes, my old sim is still active at the minute.
The My48 page says "We are transfering your number" at the minute.
Thanks
See here:
How do I keep my old number?
As it says there if the porting process seems to be taking "too long" then contact 48 support directly by logging a support request.
I had to contact 48 , and they had to get back onto three to release my number , it took 3 days:(
