Using iphone as hotspot for laptop
foluwashola
Hey there,
Just got the Mitch membership plan and am trying to hotspot my laptop via wifi. The laptop connects to it but then says it only has limited connectivity and I'm unable to actually use the internet on it. Any pointers?
Thanks
Make sure that your internet/APN and personal hotstpot settings are correct - follow the instructions here including the ones at the end for configuring the personal hotspot:
Can you use the internet on the phone itself (while not on wifi)?
If not then please post back with as much detail as possible about your configuration and what does or does not work.
