Using fone abroad,
bugeyes
Hi, Last two times I went abroad I buy an add on,
But I was unable to either make calls or send texts,
Can anybody please advise as to the correct settings for my fone, thanks in advance
If so then it was probably this issue:
iPhone abroad issue
Blame Apple for the stupid way that they do things unfortunately.
It's not under 48's control.
