Top up
I've topped up and bought membership but my minutes have not gone up it says I've none left.
Hi.
If your membership is not due to run out for a few hours/days - your present plan & residual minutes will be displayed on your my 48 page.
However - you will see the next stacked membership highlighted in green below your current active membership.
At 1200 midnight on the renewal date that applies to you - your new membership and minutes will be clearly seen at the top.
Can you check your current plans expiry date, and that the new membership is as described above - & post back?
