Top up code already used
crazy_giraffe94
I just bought credit and it says that the code has already been used so I can't top up. I'd appreciate any help.
Sounds similar to this other recent case:
http://community.48months.ie/t5/Need-Help/Top-up-not-valid/m-p/39428#M15980
You'll need to contact 48 support to get them to sort this out:
crazy_giraffe94
Deadly thank you
Did you get onto 48 support and get this issue sorted?
crazy_giraffe94
Yeah I contacted them on Facebook and they were able to sort it out for me
OK glad you got it sorted.
