Someone posing as 48
freshprince
Hello,
 Today I got a text from an 089 number claiming to be 48. It read : This is a friendly call/ text warning as you're reahing your fair usage limit & if you break that ou will be suspended. You don't want that! Further info here:
He then posted a link, which I didnt click. Is this some virus or do 48 actually contact people using an 089 number...
It's not a scam. It's a warning from 48 (who use 089 numbers by default other than where customers port other 08X numbers over) that you are in danger of breaching the fair usage limits and getting barred for the remainder of your current monthly period.
If this happens once then you cannot use services until your current membership and your ban period ends. At that stage you need to contact 48 support to get reinstated. If you get barred for a second time it's for good.
Thanks how can I see how many texts I sent?
Unless your phone records that locally I think you'll have to ask 48 support for those details.
Remember that long texts sometimes use up two or more SMS messages in case that's relevant.
