Sim
woody02
I got a text from 1749 saying it can't connect to my phone I tried using tweakker and it won't work I bought this iphone5s unlocked from my friend and he used 48 this is my first time using 48 I bought membership ad everything nothing seems to work I can't ring or receive call texts or anything or use my mobile date...please help
Two things -
(1) To configure your internet settings follow the instructions here:
(2) iPhones can need activation on some networks due to the stupid way that Apple does things. This process automatically sends a UK SMS which on 48 costs 25c so you need some cash credit on your account for this to work. The process should happen automatically after a while once you have cash credit for that message and you switch the phone off and on again. In some cases it may required a sync with iTunes. Unfortunately Apple make things even more complicated by not clearly documenting this process and what to do in what circumstances.
woody02
I've tried configuring the internet settings but it isn't working?
You need to also try what I suggested in point #2 above.
This is an issue with iPhones due to the stupid way that Apple do things.
