Sim
mudite1988
Hello 😉 if i need sim card for iPhone 5 can I use new starting kit!!i have new SIM card at home! Or I have to order it again? There is any chance to ring you?
If you have an existing new SIM that fits then DON'T activate it but contact 48 support and they should be able to set it up on your existing account/membership/number:
If you activate the new SIM now then it will be on a different account/number etc.
You cannot contact 48 support other than online. I.e. you cannot call them.
