Sim card is provisioned
Need sim card re-registered, been away for a year so phone was use, can you fix this please
Number on the sim is
8935311100202477940 R
You need to contact 48 support about this:
If you were away for much more than a year then your original account may have been deleted and your number reused in which case you will need to start afresh with a new SIM, account, number etc
But only 48 support can clarify for sure what the options are here.
Hey thanks for the reply, my account is still open just won't pick up reception to buy membership, my number I carried over from Vodafone so they can't reissue it to anyone else, it's not there's to do so.
Did you contact 48 support using the link that I posted?
Only they can sort this out for you.
I did thank you, they still haven't got back to me.
Thanks for you help
For your info...
Guide on how to get help
How long does it take to get a reply?
The 48 support crew work 7 days a week; from 9am to 9pm Monday to Friday and 10am to 8pm Saturday & Sunday. They'll get back to you within 24 hours. If it is something that has to be looked at by the techie guys, it can take between 3 and 5 working days to get resolved.
