Signal
is anyone else having problem with signal??? Mines been gone for 2 days and im stuck in emergency calls! i always have full signal in my house and now none!
Are you in a poor coverage area?
http://community.48months.ie/t5/Most-Popular-Questions-Knowledge/What-s-the-network-coverage-like/ta...
Maybe log a support query to ask 48 about this:
12 REPLIES 12
truered1
Keep losing signal and have to restart phone for it to return
Try switching off, taking the SIM out, gently cleaning the contacts, putting it back in, switching on, manually searching for networks and connecting to 48.
If that doesn't help then you might need to try a replacement SIM.
You might also want to contact 48 support.
Did that help at all @truered1?
