Signal strength
podgesully123
Is there any way that the signal can be improved in the faha area in Kerry as internet is very slow and is on E, 3G occurs but very seldom if this problem could be solved it would help not only me but other 48 customers in the area besides that everything else is perfect.
You probably should log a support query to ask 48 support directly about this:
I suspect that it will only improve if/when O2 enhance their coverage in certain areas.
Looking this data coverage can be patchy in certain areas of the country even if voice coverage is close to 100%.
http://www.o2online.ie/o2/coverage-checker/
This site is also useful for checking details of available mobile masts etc.
http://www.askcomreg.ie/mobile/siteviewer.273.LE.asp
