Service roaming
Roaming in uk.. No service at all ...paid the roaming offers but no service
Hi robd7
Which roaming add-on did you buy for your membership ?
Did it work for a while and then stop or had it not worked at all ?
Yours,
Camille
Community Helper
I paid for both add- ons.... It hasn't worked the whole time
Hi robd7
I suggest you send a message to one of the techie agents on here. They will check for any problems and get your problem sorted.
Yours,
Camille
Community Helper
What network are you connecting to in the UK? Maybe try another one? For what it's worth I'm just back from France and had no problems roaming and using the EU roaming calls and text add-ons.
