Showing results forΒ
ShowΒ Β onlyΒ  | Search instead forΒ
Did you mean:Β
Searching....😠😠
My phone keeps saying searching up on the top left hand side of the screen. This has been happening for months on and off and when it does it won't allow calls or texts. This is very annoying because it has been going on so long. Lease ease can you get to the bottom of it. My number is **bleep**. Also I am travelling to emglmd next week Nd want it sorted by then.
EDIT: Removed personal info
See if this helps.
http://community.48months.ie/t5/Need-Help/I-activated-my-sim-and-it-still-won-t-work/m-p/41130#M1712...
If not then contact 48 support for advice:
