Satnav
I want to use a satnav app in uk and France but not sure if this would be prohibitive cost wise. Is it a matter of an EU add on and would it be used up very quickly. Using it with my current Guido membership stopped when I entered N Irl
If the satnav requires a carrier data connection (do they?) then it will not work because 48 simply don't support data roaming abroad.
If it can download the maps/directions (e.g. over wifi) for use offline (i.e. without a carrier data connection) then it should work fine.
It will presumably use the GPS to figure out your location but that doesn't cost anything on any network.
Ok great thanks. That gives me something to go on. Thanks for your help
Great. Glad it helped.
