Roaming
chrisraf
I was in lanzarotte for 3 days from 4 to 7 March - I topped up with EU roaming before I went to the value of €5.50, my sim would not work over there or could I connect to another server- I will lose the credit the end of he month - can I be credited to my account for the value of €5.50 ??
7 REPLIES 7
In that case you need to be aware of this when roaming:
iPhone abroad issue
It's a stupid iPhone issue that keeps hitting people - and not just on 48. Blame Apple. Man Indifferent
If you think that you are due a refund then contact 48 support and ask them about it:
chrisraf
Hi thanks can't seem to b able to contact 48 support - keeps throwing me back 2 ask the community !!
On the iPhone app or on the website?
Do these links not work?
https://server.lon.liveperson.net/hc/62134218/?cmd=file&file=visitorWantsToChat&site=62134218
If not then email support here:
support@48months.zendesk.com
You could also post your question here in case anybody in the community forum could help?
chrisraf
Great thank you got sorted & refunded 👍
Great - glad you got sorted.
