Roaming can't find network in Spain
donomahoney
In spain , bought roaming texts and calls but still can't find a network any suggestions on iPhone 5
Same old iPhone roaming problem.
See here but adjust for 48 as needed:
https://www.tescomobile.ie/support/question.aspx?id=135
If you don't do this before going abroad then it can be tricky and take several attempts to do it when you are already abroad.
One tip seems to be to reboot the phone and when it try to catch the option as the phone temporarily/briefly manages to connect to a local network before it disconnects again.
donomahoney
Thank you so much for the help
Glad it helped.
