Roaming Internet
jmaljnr
Hi,
is there a way to buy an internet add-on for roaming, like we can with texts and calls?
John.
You mean for internet access while roaming abroad?
Unfortunately not. 48 don't support data/internet access while roaming abroad at all.
While abroad you need to make do with wifi access wherever available.
14 REPLIES 14
@tarmonator wrote:
Same happened me.
What do you mean?
Same what?
Any update?
derekn123
When the issue was raised if you clicked on the EU roaming add ons link you were directed to the Add ons panel and you could buy 1Gb of Internet. This mislead me to thinking it was for EU roaming when it was just for out of package usage. I just checked there and you cannot do this anymore as the add to cart button is not highlighted
Thanks.
So it's still unclear what hammerhead is referring to if the original issue that you mention is no longer present.
This new announcement is relevant here:
https://community.48months.ie/t5/Most-Popular-Questions/Going-away-Using-48-when-roaming/m-p/44774#M...
