Replacement sim
I have ordered a replacement sim a week ago and have yet to receive it and as a result have not been able to use my number which is very inconvenient.
Can you please advise me of the delay and how I go about ordering a second one.
Kind regards
Aoife
It shouldn't take that log according to this:
http://community.48months.ie/t5/Most-Popular-Questions/How-long-do-I-have-to-wait-for-my-SIM/m-p/26#...
You should log a support query to get 48 to look into this for you:
6 REPLIES 6
waiting for my relacement sim thank you
Did you order a replacement SIM? If not then do so. If you did then wait for it. If it's taking too long then log a support request to get 48 support to look into it for you.
abdullah_safi
Hi my phone number is black how can I open this number please can you Gove me advice thanks
Your post/query is not clear.
What do you mean by "my phone number is black"?
You seem to have posted a similar query back in 2014 and it was not clear then either...
http://community.48months.ie/t5/Need-Help/Blocked-sim/m-p/27167
Any update?
