Replacement sim
hi,  i could not register my replacement sim. it says 48month were unable to register my sim and to contact an agent.   when the sim is in the phone it says the sim is closed. what to do next?
Edit / script removed. -Marion
See here:
http://community.48months.ie/t5/Need-Help/Replacement-Sim/m-p/21245#M6461
You need to contact support as the website told you.
See here:
