Phone can't find a network.
I can't send or receive a text or call my phone keeps saying it can't find a mobilr network and will try again later Ive checked my mobile networks settings and fixed them but it's still the same. Any ideas or help ? I have screen shots of the messages that keep piping up
Manual scan did the job thanks . Great help 😄 so quick 🙂
Did it ever work properly?
If so when did the problems start and did anything change on your phone at that time - eg software update, settings changes etc?
What make & model is your phone?
Can you post the screenshots of the errors?
Can you do a manual scan for networks? What do you get?
Have you tried switching off, taking the sim out, gently cleaning the contacts, reseating it, switching on and doing a manual scan for networks to see if that helps.
Great. Glad it helped. Hope it keeps working without issues now.
