Paid membership, still no calls texts or internet?
marklbarry
Paid membership, but I still do not have calls texts or internet?
If calls and texts are now working but not internet then you should try enabling data roaming.
I'm assuming that you have also already configured your internet/APN settings?
http://tinyurl.com/kys43lv
7 REPLIES 7
Did this work before or are you new to 48?
What does your online account say about your membership status, expiry date and calls/texts/data allowances?
Can you receive calls/texts?
Do you get a signal at all?
If you are not new then any chance you breached the fair usage limits and were barred for the remainder of your most recent membership month?
Have you contacted support?
Yeah it usually works, im not a new customer.
Membership says paid and expiry has been updated for a months time
Can receive calls.
Yes i have signal
no data roaming is not enabled
yes my phone is unlocked, i have been with 48 for over a year now
No i havent done anything to be in breach of the regulations?
What is the expiry date?
Does your account list a current and next membership or just current?
Strange that data roaming is not enabled - that is normally required for general and data use on 48 or any virtual operator...
Are you sure that you didn't get barred?
You might need to log a support query.
expiry is the 26th March, I only paid the membership today, could that be a factor?
Just current: The Don
Should i activate my data roaming then?
Yeah i'm sure, i cant see what I would have done to warrant being barred.
I've logged a support query, thanks anyway
If your expiry date is 26th March then suggests that you have a current membership which runs until midnight tonight (26th February) and then your new membership kicks in at midnight.
Maybe you have simply used up your allowances on your current membership? If that's the case you may need to buy add-ons to use certain services today before the new membership starts at midnight.
My calls and texts are now working but still no internet? I assume theres something wrong with my internet settings?
