Not receiving texts on time
gmdh
Sometimes a text only comes hours later than it was actually sent to me and sometimes it doesn't come at all.
First thought it might have been my phone but I recently upgraded and yet the same keeps happening, very frustrating
7 REPLIES 7
You should contact 48 support and they may be able to investigate this issue for you:
Did you get onto support?
Were they able to help?
gmdh
Yes, thanks.
It was probably a problem with the sim so I'm gonna get a new replacement sim
OK - hope that helps.
Thanks for posting back.
I've had the same problem all week. What gives
You probably need to contact 48 support as mentioned earlier in this thread.
Any update?
