Not Making/Receiving Calls or Texts
juliand2
Hi,
Since yesterday afternoon my phone has not been able to make/receive calls or texts. The top of my screen no longer says 48, it says I can make emergency calls only. I've tried my sim in other phones and the same thing keeps happening. I think my sim card could be broken, but I'm not sure. Any information would be very helpful.
Thanks,
David 🙂
Have you tried cleaning the SIM contacts gently and trying it again?
What networks can you see when you do a manual scan?
Can you see/connect to 48?
If you still have problems then you may need to contact 48 support for advice/assistance:
Did you get anywhere with this?
