No network
bunsonburner
My Network has been gone since last night. My girlfriend is 48 too and worked perfect for her. Im using a Motorola Moto G phone. Ive tried turning the phone off and back on again with no luck. Ive also tried going into settings and searching for network. Vodafone, O2, Three and Meteor all show up but not 48.
Any suggestions?
bunsonburner
Fixed it.
Took the Sim out n put it back in again. That sorted it.
bfkthomas
Hello. Can someone help me, I'm in Sydney and I need to connect 2 a network which are YES Optus or Vodafone Australia. I have a new phone Iphone 5 I'm not sure how 2 do it on this phone
Tks Thomas
Hey Thomas
On the iPhone 5 you can go to Settings > Carrier and ensure Automatic is off.
You should then be repsented with a list of available networks.  Try connecting to each one to see if it works.
If the above fails, go to the Settings > Phone > SIM Applications and select When Abroad/Network Selection > Manual > International - Roaming profile. Then search manually for a network and try to connect.
That should work for you.
Damian
