No network coverage
MarianM5190
Hi, I have had no network coverage at all since last night. It keeps saying enter pin and then the same thing happens again and again. Please get this fixed as its extremley frustrating. Is there coverage problems in the Galway area???
Is it asking for the PIN after you reboot the phone?
If so then that's SIM PIN locking which you can disable if it bothers you.
iPhone: https://support.apple.com/en-ie/HT201529
Android: https://www.digitalcitizen.life/how-change-or-remove-sim-pin-android-2-steps/
If you do a manual search for networks can you see and connect to 48?
Did anything change on your phone recently?
Software update, settings changes, factory reset?
What make and model of phone?
If necessary you should contact 48 support.
