No Service in France
Both our iPhones (5s & 5c) won't connect to Network in France. I have 40 euro credit on my account. Just get Searching... or No Service.
Have checked and searched for every solution possible online including 48 forums.
8 REPLIES 8
Could be the usual hassle with iPhones when roaming abroad.
Try this and hopefully it'll help:
What do you mean "kinda working"?
Are there still problems?
Would you be able to post the correct menu path for the benefit of others?
No. Those Settings don't exist on my phone. iOS 8.3
OK - I don't know why this is.
I asked this a while back - i.e. if the relevant settings were only on certain iOS versions or maybe depend on some other setting:
http://community.48months.ie/t5/Need-Help/roaming/m-p/34390#M12462
Unfortunately iPhones seem like they can be a lot of hassle on virtual networks (such as 48) both at home and when roaming abroad. I've never had such problems on Android but that's not much use to you - sorry.
Maybe contact 48 support and ask them for advice:
If you get a solution then maybe post it back here for the benefit of others.
Okay so I managed to find the settings as mentioned in the other thread. I think the names of some are different or I was looking in the wrong place. Sorry! And it's kinda working now.
Haven't been able to make a call yet. Not sure about receiving calls. Can send receive texts.
Will post more later.
You mean you haven't tried to make a call yet or you did and it failed?
If it failed then what exactly happened?
You definitely do have cash credit or EU roaming add-ons to cover outgoing (and incoming) calls?
Could you post the correct menu path to the iOS/iPhone setting above if you get a chance please?
